Results 1 to 6 of 6
Thread: Alternative body for Cutie Delf head?
  1. #1
    I have a Cutie Delf head, but need an alternative body since they're not available. Any suggestions? They're very small and childlike (26 cm height), which I love. The head is 18 cm and the neck 8 cm. Resin match would be great, but I can fake it if it's not exact. Thanks for your help.
    Does anyone have both a Cutie Delf and a Dollzone tiny? (I'm thinking cheap, here.) Thanks.
  2. #2
    I only had a white Dollzone ...I dont have her now
    so I cant match up the colour ..
    Im pretty sure the size would match though
    and the head would go on a DZ body
    DZ and Cory have the same headsize
    also Cory has the same size head as Leeke ..SD YO , Lati Green , Petite AI
    but body size you may find any of those fit ...they arent as chunky as the Cutie body ..LATI and AI are taller ...
    but I think any of these may work
    although resin match may need a little work
    my Mums Cory is very pink you may have to blush the neck of these slightly
  3. #3
    Thanks, tinybear. I've had this little head for about a year and almost forgot about her (Cory girl!). I ran across her little head while I was searching for something else and she gave me a very cross look, so I guess I had better get busy with her.
  4. #4
  5. #5
    I'm not sure if it would fit on Dollzone because Dollzone says their's neck is 6.5 cm around where cuties are 8.... You may want to try a petite body, of couse that would not be a good colour match
    CH Classic Sariel and Gabriel, Petite Uriel, Hanael, sleeping Raphael, Fairy Gabriel and Anael x2, and Bisou Ai PoPo, Lati Yellow Miel
    FS: Petite Ai/Yosd clothes | SD wigs and eyes
  6. #6
    great photos ...I dunno ...judgeing by those pictures
    I still think Dollzone will be your best bet
    by the colour match and the thickness of the neck
    out of all of the bodies in that line up ....if it were me ....I would go for a Dollzone and
    use a Kip ...or suede at the top of the neck to stop the head from slipping about
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
